Missing Hot Start Circuit 2008 YZ250f
so, if some one snapped the cable and "took he stuff out of the carb" how much of a PITA is it to fix it? Do I even need to?
If it's similar to my CRF250X Keihin FCR carburetor (very likely)
you can replace the whole hot start assembly (cable, lever, plastic nut etc. ) with a simple 'choke' like plunger mounted directly on the carb.
Perhaps not as convenient to reach under the fuel tank and operate than a handlebar mounted lever but
in a non-competitive usage the extra time to find and operate it is a non-issue.
Yamaha part number:  5TA-14171-00-00   STARTER, PLUNGER
I used the other part number, the larger outer diameter knob is easier to grab
plus without looking I can tell which is which by feel, not to pull the actual choke out by mistake.
Edited by mlatour
yeah but youre not the one replacing it  :facepalm:
plus it would take all of 5 seconds to learn which is which
