2014 kx450 engine noise
I have a 2014 kx450f. I'm having a gurgling noise when idling I can't really hear it when riding runs good and cranks on 2 or 3 kick when cold. I have just put a new cylinder and piston and rings in. I checked all my clearances when I put it together like valves and cylinder and piston size and ring gap and I also staggered the rings like the manual says. I also took the flywheel off and cleaned the screen it was pretty dirty this is the first time I have done this I just got this bike about 2 months ago. The reason I replaced the piston and cylinder is due to scaring on piston and cylinder when I took it apart to replace the base gasket on cylinder due to water leak when I bought the bike then discovered when I got inside I had the scaring on the piston and cylinder so I went ahead and replaced. I'm at a loss on this gurgling noise looking for some advice please.
I can try to this evening.  I have never done that before this is the first time I have ever posted anything.
