'05 YZ125 Acting Like Outta Gas w/ Float Set by FSM
I've got a 2005 YZ125 that I've performed a top and bottom end rebuild on 2 years ago.  The bike has about 52 hours on the meter (which I put on during the rebuild), and I've been diligent about replacing the piston/ring every 20 hours.  Engine-wise, the bike is all stock except for a set of VForce 3 reeds that I put on about 20 hours ago.  The pipe and silencer are stock, and I've repacked the silencer on 2 different occasions.  I run Pro-X pistons, Cometic gaskets, Klotz premix (30:1), 93 octane non-ethanol fuel, and NGK BR9EG sparkplugs.  I sealed the cases with Yamabond 4.  I've rebuilt the carb about 4 times using Outlaw Racing kits.  It's never been jetted, and I've put all of the carb settings back to the original positions listed in the Yamaha FSM.
I've been dealing with a frequent yet somewhat intermittent issue for more than half the time that I've owned this bike.  When it decides to misbehave, it will begin idling high during hard riding, much like it's about to run out of fuel, and if it's still ridden hard, it will cut out -- often on the face of a jump, which is very scary.  The bike will foul plugs from time to time if it's not being ridden at the track, and the plugs are always black, wet around the outside, and dry in the middle, so I assumed that the stock jetting was just a rich setting for safety (at the expense of the occasional plug), but figured that whenever I'm riding the bike hard, then perhaps a low float height setting in the Mikuni carb might be causing that intermittent lean condition any time the engine load depletes the low amount of fuel in the bowl.
So I followed the FSM procedure of connecting a clear tube to the bowl to see the fuel level that the float valve stops it at.  I inscribed 2 lines into the side of the carb for the 9.5mm and 10.5mm boundaries that the level is supposed to be in when the carb is vertical.  Through a lot of trial and error, I was able to bend the float tab to a position where the fuel level satisfies that FSM spec.
I thought the bike was fixed after a few hard test rides with no sudden high-idle nonsense, but unfortunately the problem returned once I actually had the bike off at a track.  I just tested the float level again to see if the setting was repeatable after all the recent rides, and it looks like it's still dead-on to me -- or at least not low enough that I'd expect it to cause a fuel-starvation type of issue.  See the pic below, and notice the 2 long lines I scratched into the carb body indicating the 9.5~10.5mm range.  The small scratch up above is for showing how high the overflow tube reaches up.
I thought I might have a vacuum leak, but I made a pressure tester and it was able to hold rock-solid for days.  I also tested vacuum on the engine, and although it wasn't as capable, it still never dropped (raised?) back to atmospheric.  I even tried heating the crap out of the engine with a hair dryer to see if thermal expansion would open up the leak and thus cause a change in either the pressure or vacuum tests, and didn't see a significant change.  My VForce 3 reed setup has a gasket on top and on bottom, and I coated both sides of both gaskets with Permatex Ultra Black RTV (like I have seen recommended here on TT for this particularly troublesome model of VForce 3 reeds).
Any idea what it could be?  For reference, I've been riding the bike at 600~1100 ft. above sea level at different tracks around North Alabama.
Welcome to the TT YZ forum.
Looks like you have a great seal on her. How do the reeds look after the 20 hrs you put on them? Check for chips and cracks, carcks you might not see unless removed and inspected.
you could have a bad gasket, letting air thtough. But my 250 will rev up when riding hard so its not too too bad, just lower your idle when its really hot. another thing you can try is move your clip one position lower
Thanks!  Reeds don't seem to be in bad shape.  I bought the VForce setup used, so they've got more hours than the ~20 that I've racked up on em.  They appear to be fine though and don't seem to be letting light pass through.  Furthermore, the super-high-idle-after-riding-hard issue was present prior to installing the VForce reeds anyway.  I recall halfway hoping that the reed swap would remedy it way back at the time because my stock reeds had a little bit of delamination and chipping at the tips.
I was expecting the stock carb settings (including the needle clip position) to be able to maintain a pretty consistent idle, even if ridden hard, albeit without making the most power or without possibly fouling some plugs.  Seems like a dealership selling a bike that would behave like what mine's doing would result in some seriously pissed off customers, and/or some injured ones because once the high idle works up, it'll cut out during a pull out of a corner or up a jump face.
I was thinking that a bad gasket letting air through would've shown up in the pressure & vacuum tests.
1 minute ago, speedtoad said:
Since its intermediate would look for an electrical problem.
Spark plug wire?
Grounds?
Stator?
I'm thinking stator. Sorry.
I put a brand new OEM stator on during the engine rebuild, so I'm inclined to believe it's fine -- especially since the high idle craziness seems to be so consistent with the bike being rode hard.
You should re-seal the reed cage assembly with Yamabond,
even if not in direct contact with liquid gasoline,
over time the vapors alone will turn regular automotive RTV to mush and create air leaks.
I once smeared a small dab around my YZ125's carburetor's top cover (cover where the throttle cable connects)
to keep the cover's o-ring in place in it's groove while changing out needle settings.
In no time the usually high strength Permatex Ultra Copper turned to a mushy mess simply from the vapors.
Your 0-60psi gauge isn't accurate enough to read any loss for this type of test,
you can easily order a 0-15psi gauge thru auto parts stores, a 0-10psi even better.
Pressurized at 6psi, absolutely zero drop of pressure for 20 minutes is the norm,
tested last summer my YZ125 went 30 minutes before seeing a 0.2 psi drop.
Edited by mlatour
I think it serves just as well since I made up for the low gauge resolution with really long amounts of time (like "2 days later" as seen in that pic).  Because, as we can see, it didn't really leak that pressure down.
I've just ordered some Yamabond 4 (I borrowed some of my friend's 2 years ago when rebuilding the bottom end).
I'm about to remove the carb boot and reed cage to see if perhaps that black RTV has broken down to mush and caused a vacuum leak there, which would be ironic because that was the first place I suspected a leak back months ago when I started investigating everything, and that's when I got a second VForce gasket and applied the black RTV.
It was weeks later that I suspected the float level to be low (which it was) and began sorting it out, so if it all comes full circle to currently being a vacuum leak from the reed block gasket that is causing pretty much identical symptoms to what the previously low float height caused, then holy crap -- what a diagnostics nightmare.  Lol
So I ended up deciding to not remove my reed cage right away because that could cause me to miss the opportunity to truly diagnose the problem.  Ended up going to Home Depot to get a low pressure gauge to put on my pressure test rig.  I figured, if the RTV on the reed block gaskets was the issue, then it ought to fail a pressure test (and presumably a vacuum test too).  However, so far it's looking like it's holding pretty steady (see pic).
I got a float height gauge in the mail today.  Figured I'd see where my current float height setting is when going by the method Honda uses in the '06 CR125R FSM since they used a 38mm Mikuni as well.  For those that don't know, Yamaha's procedure is to attach a clear tube to the drain plug of the carb bowl, fill the carb with fuel, then compare the height that the fuel stops filling at -- like what I showed in the original post.  Kawasaki uses the same method on the '01/'02 KX125 as Yamaha, but with a different spec (2~4mm above the bottom of carb body, as opposed to Yamaha's 9.5~10.5mm), which is strange given that their both Mikuni's.
Both Honda and Suzuki use a different method -- their FSM's say to check the float height by the more common approach of tilting the carb over at the angle where the float tab just contacts the spring pin on the valve in the closed position, then measuring the distance from the body of the carb to the bottom-most tip of the float plastic.  They have slightly different specs (7.5mm for Honda, 7.7~9.7mm for Suzuki).
My Mikuni's current float level setting, which I believe meets the Yamaha spec, measures out to 9.75mm by the Honda/Suzuki method.  If that other manufucturers' style of measuring float height has any credence to my YZ125's high-idle-leaning-out-only-when-ridden-hard issue, then perhaps I should try bringing the float level up to Honda's 7.5mm spec?  Because, by comparison, my current 9.75mm setting is lean.  But on the same hand, compared to Kawasaki's spec, mine has too much fuel in the carb bowl, so perhaps there's other differences in the 38mm Mikuni's between these manufacturers?  I know some have a throttle position sensor, but I wouldn't be surprised if the float functions are no different.
