not going into 4th gear
I bought a 2015 Apollo 125cc pit bike and was riding the other day and while i was putting it into 3rd gear it felt like it was losing power. After i got it up and put it into 4th gear it stalled out. I started it up again at neutral put it in first and it was fine clicked up to 2nd and it was fine then when i clicked up to third it did the same thing all over again and started to lose its power After that i didn't even try to put it into 4th. Any way you can explain or try to help me out? Thank you!
Not sure what the Appollo is a replica of, but I would imagine at minimum you're going to pull a side cover and look at the shifter mechanism.
Hopefully you won't have to split the case.
Don't know what those bikes cost new, or if you can get parts for them, but you might consider another new bike, and keep the current bike for spare parts. :excuseme:
Check the valves and if needed, adjust them to .002" for the intake and .003" for the exhaust
I read the post again.
I believe I may be misinterpreting the problem.
Loss of power, not mechanical.
Anything helps at this point. Thank you.
A tight valve that does not close all the way lowers the compression and drastically reduces power output.
Thank you! i will have to check out the valves!
