Getting a stuck flywheel off
Got my new tool in the mail, and had a crack at getting the flywheel off my wr426
It did not work. The bolts bent, and 1 of them had the threads ripped off. Seems like the holes in the tool didn't perfectly line up with the flywheel, hence why they bent a little.
This is the tool I used, which said in the description that it was only for the yz/wr400, but the part number matched the one provided in the book for the 426 so I figured it'd be right
5982e5b52c793_flywheelpuller.thumb.jpg.ef47410041dece5121edae800a4c58b2.jpg20170803_185204.thumb.jpg.769da71d55752ffed6712f208bbf3734.jpg
This is the bolt that was ripped out. Threads are f***d. I think the flywheel is ok, just has the remains of the bolt threads in it for this one hole.
What can I do to get this flywheel off? Seems like I'm down shit creek without a paddle now that this tool has proven it won't get it off.
Seems like the wrong one if it doesn't match patch numbers.
Before you thread another bolt into you, you will want to run a tap through the one that has the remains of threads in it to clear it out, then blow some compressed air through to get the metal shavings out. You do not want to strip it out or crossthread it.
Take a look at MotionPro's website or catalog, they make a puller for it.
Don't thread the bolts in too far or you will damage the coils.
It did match part numbers.
Good idea with the tap
Any ideas on how to make it come off? Even if I've somehow got the wrong tool and I need another one, the bolt didn't rip out until I applied a hell of a lot of force to it using a 2 foot breaker bar
Sent from my SM-G920I using ThumperTalk mobile app
Are you using anything to hold the flywheel?
Yeah I had a bar through the piston connecting rod resting on a rag on the side of the engine, which stopped the engine from turning
I would try an impact if you have one. The hammering force will be what gets it off.
8 minutes ago, thredbo said:
Tried that. Didn't budge
Was it air or electric?
You might be able to try a fan clutch tool if you can get it to work.
those bolts are useless - you need high tensile bolts
It it ok to apply a hell of a lot of force to it though? I felt like I may have been applying too much force, but maybe it's what it needs
yeah they need a shitload of force to get them off - thats why you need the right bolts
are they m10 metric ?
Cant remember off the top of my head, looked more like an m8 or m6 size. Pity they're not bigger, they'd probably cop more force before failure
I get alot of stuff from mxstore
but those bolts just wont cut it
give them a call tomorrow and let them know - they might send you out the proper puller
or go get some high tensile bolts
Yeah righto I'll give that a shot
I might grind the holes on the plate inwards a little bit with my dremel if they don't send a better one - might reduce the stress on the bolt
