2001 RM125 !
If the bike has it's original shock spring, with you weighing 85kg (187 lbs) it is too soft.
No matter how much you tighten up the preload to raise the rear, it will ride low and soft.
Bike manufacturers set up most 125's for a rider in the 140-150lbs range. (66kg), meaning you likely need a stiffer spring.
It's also a 16 year old bike, when has the shock's nitrogen bladder last been serviced / re-charged ?
Edited by mlatour
