Hey guys quick question here I bought 8ls 2002 Yamaha YZ 125 and It came with the incorrect carburetor it has a 28 mm carburetor so I went on eBay and purchased a 38 mm carburetor that was removed from up CR 250 my question is what jets do I need As far as I can tell the bike has a pro circuit exhaust and vforce reeds i live down in miami
Ok,  it came off of a cr250.  Which model cr250?   cr250's came with mikunis and with Keihins depending on the year.   The 250's jetting is most likely too lean for your 125.  That means the needle,  the main jet,  the pilot jet,  and slide are very likely to be less than optimum for your application.
Its a mikuni tmx 38mm
can anyone help with this i already blew an engine and am currently rebuilding it and need to know what jets i need
No visible number on it when i pulled it out only thing i can say is that the clip was in the middle setting what im trying to find out os what jets would i need for mine
I am seeing numbers on everything you put pictures up on so far.  Do you think you should see an eye specialist?
Maybe, post up question in YZ125 forum to see if anyone has gotten a 125 to run well with a 38mm carby?
