2017 FC250 suspension settings
Getting my bike this week and I'm wondering if there are other 160lbs riders around on a FC250 who can share a bit of experience on suspension setup.
I ride 100% MX/SX tracks.
thanks 👍
here are mine after 30 hrs use.  i am 155 mx only rider.  fork air 9.9 bar, 15 compression, 12-18 rebound.  rear shock, 1.5 turns out on hi speed compression, 12 out on low speed compression, and 8-11 out on rebound.
And how many mm of Pre-load on the rear spring?
Oops, 27mm of static sag. I don't do rider sag.
If you have a minute, I'd really like to know two things.
1. What are the numbers on your spring.
2. What is the distance, in mm, between the top of the thread and the top of the red plastic pre-load nut. How much thread is exposed.
Thanks.
