Rm125 help
I just rebuilt my bike and it wont start it just sneezes when i kick it whats the problem
What model and what year?
What was done in the rebuild?
Compression test?
well if it has low compression it will be difficult/will not start.  Assuming the rebuild was quality work you should have enough compression for it to run. check that the carb is clean, getting fuel, and the float level is set right. Check for spark. check the stator plate and make sure the timing marks are lined up. make sure the key is in the flywheel.
need compression, fuel, spark (at the right time) to run.
Think ill mess with it tomorrow man you been a big help i thank you for it theres barley any videos on YouTube that help
On 8/8/2017 at 0:37 PM, mari_hr said:
97rm125 i bored the cylinder 80 over and new piston and gaskets low compression
80 over!  Do they even make pistons and rings for that much over bore?
