Rear shock loose?
The upper bearing is of the spherical type. Having side to side play when mounted in the frame is not a concern. Just be sure there is no up and down play at the upper bearing, as that is NOT normal.
I can not move the shock up and down in the frame but I can move the bearing up-and-down with my finger while the shock is out but it's very slight...still worth replacing?
Even if it was bad enough to replace, you'd have a heck of a time locating one. You'd have to buy an eBay shock and rob it of its bearing. That bearing is not known for going bad. I bet anyone of us could check our bearing by hand, out of the bike and it would have the same slight play. I think I'd let it go.
The bearing is not available but the dust seals are, so you could replace those.
Afternoon XR400ex, , while your down there/in that area it would be a no brainer to check all the linkage pivot bearings an the infamous swing arm bolt. They need regular service/ lubrication also
. Just a thought. G.
So I decided to let the play in the upper bearing go but I replaced the bottom bearing in the swing arm linkage end. That one had much more noticeable movement and since I had the part on hand it worked out well. And yes, G, I did go through the other bearings and grease them as needed. I figure I will eventually be rebuilding the rest of the rear pivot points next season so I wasn't too worried about it but just so I can get a little more use out of them. Thanks for the info
Hey guys, got what I believe to be a problem on my XR. Just noticed that I can move the entire shock left and right while it is still bolted in. It isn't just the spring moving it's the entire shock. I have it out now and I am looking at the bearings (upper and lower) but can not seem to find anything out of the ordinary. Any help on this would be great
