Idle isn't right
When I'm putting around at low Rpms it wants to act like it's stalling with popping sounds. Carb was just rebuilt. What could it be?
Change spark plug, check clutch, and recheck carb.
If it didn't do this before the carb rebuild I would suspect it to be the carb. I suspect it to be a carb issue anyways.
The reason I had the carb rebuilt was because it was doing this. Could it be a valve prob?
Very well could be but typically bike will be hard to start and get worse the harder the bike is run.
Try playing with the air screw on the carb.
Ended up being exhaust leak
