Bought a kx 100 very clean owned by the same guy for many years ..Anyhow want to spend on new parts piston etc ,so i checked the vin and engine number ..The frame has a CC for its 9th and 10th digits which i think is an 82? the engine has a kx100 ce 002751 which the way i am understanding this is a 98/2000 .Other than someone swapping engines and frames have i got this right ? many thanks in advance any light would help
Whats the frame number ?
CE would make it a 2000 engine going by a google search
any pics ?
the frame says C.C for it 9th and 10th digit complete index is JKAKX 100 CC A005379.... i spose it possible the engine could have been swapped
the number from the head stock is as previously stated JKAKX100CCA005379 , engine number is kx100CE002751 are there any other numbers i should be aware of ? The bike has usd forks disc' front and rear ,power valve ..The tarting ha become a little difficult o i would like to change the top end take look etc ,the air filter was bad when i bought it so some signs of neglect were apparrant ,till run ok when started but its the wifes bike so it has to be right ..
