problem after changing gasket DR650SE
Help! What did I do wrong? Bike is a 93 DR650SE
The crankcase cover was leaking oil on the clutch side so I changed the gasket.
Everything seemed to go fine. The next day I took a test ride. After about 5 miles I stopped and checked for leaks.
No leaks but engine smelled hot. I let it cool down for 30-40 mins.
When I went to start it again it felt stiff to crank but started OK.
I rode to the nearest gas station to fill up but didn't make it there.
I started hearing a faint high pitch chirping which gradually grew lodger and became a high pitch scream.
I pulled off the rode and shut it off.
I have not attempted to start it again.
Engine will turn over when kicked so it is not ceased.
Any ideas?
-sbennett1298
Any ideas?
-sbennett1298
Have you checked the oil level properly per the manual? I'm assuming you had to do an oil change when you replaced the gasket or at least a top off?
The oil level is good. I put in two quarts after changing the gasket and it shows full in the site glass on the crankcase.
are you certain the gasket was the right part number? if a passage was blocked, oil flow could be restricted to some place
Both gaskets have the same holes. I know this because I traced the new gasket onto a sheet of cardboard and saved the pattern before installing.
OK mystery solved. The seized engine was not the result of anything I did changing the gasket.
I have since taken a close look at the oil I drained out when I changed the gasket and it was full of metal shavings.
This tells me the damage began before I replaced the gasket.
It looks like I damaged the engine by running with low oil before I discovered the gasket leak.
Dangit!
It's a 24 yr old bike.
If parts to repair are not available what other year engines will fit a 93 DR650?
-sbennett
