97 xr200 head gasket
Thanks for that, just what I needed to know, I will try and get her through the season as it is an "engine out" repair & I have just finished a winter rebuild on my XR250R and really don't need another tear down/rebuild project at the moment.
Sounds like an OE head gasket, base gasket and a set of rings for good luck.
thanks
Need a bit of advice here chaps if you could,
My daughters 1997 xr200r has done one season of trail riding on a rebuilt engine and the head gasket is weeping oil out of the right hand side already,
When I do the head gasket again are there any tricks to make it last longer ? I thought i would use a Honda head gasket and get the barrel & head faced,
Any advice would be welcome as I don't fancy replacing the head gasket every winter.
thanks in advance
