Grey oil 2008 yz250f
I am getting a greyish oil color in my oil. I know that usually with head gasket its milky color on cars but doesnt really look that milky. I read it might be from the clutch. All the post i have searched usually has no pics to confirm if mine is the same color. I just got the bike and this was the first oil change. I did drain and fill coolant and took it riding for a day at the track/trails. I did lose a little coolant but i also did overfill it. The coolant is sitting right above the fins after the day of riding and a few riding trips. Also not sure if this matters but the bike did get laid down twice while riding not sure if a little coolant could have came out the overflow hose during that time.
I cannot get pic to upload so here is a link to it. I will try again later to get it to upload directly in here.
https://ibb.co/cvXCcF
Edited by wrestler157
Add picture
13 minutes ago, trackmaster said:
Water pump seal?
Sent from my SM-G900V using ThumperTalk mobile app
Was thinking that also. Would a pressure test reveal this or does that only reveal head gasket?
It seems to usually be the problem on bikes with just 1 oil resevoir. You should try replacing those first before the head gasket.
