drz 400 oil issue Help
just purchased  a 2007 drz 2400 miles. changed oil , anti freeze, cleaned hidden screen etc.  Put in 2 ct synthetic , took half an hour ride runs great. No oil on stick followed
instructions, anti freeze still clean.   Let idle 5 minutes waited 3 min still oil on stick, no noise etc  Whats up?   Lost
Your post is almost incomprehensible. To check the oil via the dip stick the engine needs to be warm. Immediately after engine shut down is when you should check the oil level. Even after just a few minutes the oil will settle from the frame reservoir back into the engine.
