Boyesen Quickshot2
Just rebuild carb in my 2007 CRF250R. New jets , acc pump , extended fuel screw and also added Boyesen Quickshot 2. Set the acc pump just right and have the fuel screw at 2 1/4. Bike does run better then before but still has the damn bog. I have had the carb apart 3 times on and off the bike and I find any issues. It seems to be a lean bog. Ready to throw the bike off a cliff.
Any suggestions ?
Wish I never opened the Quickshot 2 and just sent it back for a 3 ...
I have installed a QS3 before. Does the QS 2 have an adjustable leak jet screw?
10% of the bog can come from a lean pilot fuel screw, so make sure you have that set up properly:
Make sure you have your AP timing correct:
