Where do these bits go??
Hi Guys,
A customer brought me an '09 CRF450X motor in pieces :facepalm: and tasked me with rebuilding it . I've managed to identify where nearly everything goes using parts diagrams, except the two parts in the photo:
The washer has an ID of approx 14.36mm and OD of 20.80mm. It was stuck to the flywheel but there's already a smaller diameter washer to go there and the parts diagram only shows one washer on the end of the crank
The rubber piece was in a box full of both LH and RH cover parts. It looks like some sort of camchain damper but doesnt fit on the chain guides or anywhere obvious. I cant find it on the diagrams anywhere. It might not be part of the bike but i need to know.
Unfortunately I dont have a workshop manual or torque setting chart so I'm having to use my noggin here.
Couldnt see anywhere that rubber piece goes - looked at all the schematics
the only place that washer i could see is here - says 14mm on the schematic
11 hours ago, Pancho_Jsy said:
Sorry to bump this up guys but plenty of you must have stripped these engines. If no one recognises the rubber piece I can bin it and get on with the rebuild.
Post a better picture of it...
