Cylinder head mating surface imperfection, need advice
The adventure continues. I have been cleaning up the cylinder mating surface and found this:
When I run my fingernail over it I'm pretty sure I can't feel it, maybe ever so slightly, but I am still concerned about it. Any advice would be appreciated.
Insignificant and not subject to combustion pressures. I always copper coat all head gaskets anyways and that will eliminate and potential coolant seepage.
How many coats of the copper stuff on the gasket? What made you start using it?
One to two LIGHT coats per side the night before assemble. You want just a thin film. Less is better then more.
While most head gaskets do have a sealing compound on them, this is a extra layer of security. You apply it 12 to 24 hours prior to assembly so as the material, while dry to the light touch, still has 'give'. As you assemble the engine, place the parts EXACTLY where they go, do not slide them about, that scratches/wears even the OEM gasket coating and can be cause for failure.
When are these surface imperfections a cause for concern? What's the measure for replace / machine vs run it?
Normal method of checking is with a straight edge and a bright light, if light passes, then it needs to milled flat. If it is a nick, the typical test is 'does it catch on a finger nail or is it a point of where head gaskets have failed?
Your head looks fine
As said above, nothing to worry about. Its more of a mark than a scratch from what i can see
It'll seal fine
How clean do the mating surfaces need to be? The gasket material came right off, its as clean as it will get without scotch brite, which I prefer not too use.
So I still haven't put the head back on. I was looking at it again tonight and I determined that when I run my fingernail over it I can feel it, albeit just barely. Doesn't catch or anything, but it's definitely a scratch. No idea how it ever would've got there, not by any dowels or studs.... kinda wonder if it's from the factory. First time apart. So the ultimate question is, now that I have determined I can detect it with my fingernail just barely, am I still good to put it together? More picsIMG_0839.JPGIMG_0840.JPGIMG_0841.JPG
Well I got the head back on, but the bike is not assembled to the point of starting it yet. Went pretty drama free, moly lubed the threads and mating surfaces of the bolts, torqued the bolts in the manual specified order in two stages, 13 and then 27. What was odd was I went around a couple of times after the first round of 27 and the kept tightening until they all settled out at 27. It was different, sometimes they would start almost tight, loosen some, then start tightening back up. But they all seemed to settle out at 27 in the end but I was getting worried when the started to feel loose while tightening. That's usually the sensation of stripping a bolt but they all settled out at 27 so idk.
Prob just gaskets compressing and everything seating
If they have held 27 then you are ok
