Fork Shaft Damage/ Also Fork Bushing Replacement
At the point of doing the fork shaft bushings for my 03 CR250R, also I am noticing a wear line on the chromed shaft as well. From the  seal and down about 12 inches its a line that  goes straight down the front of the shaft on the left side fork. Haven't opened it up to see what could be causing it but I figure it's due to worn bushings. Any insight on this issue?
Also what is your personal experience with the Pivot works and Race Tech shaft inner and outer bushings?
