Crf150F float height
Does it look like I'm doing this correctly ? Bike is level. Pictures below is with bike off.
IMG_1676.thumb.JPG.8842ba90343e43ad1a30cb36a7ad9efe.JPGIMG_1677.thumb.JPG.924bd85a8efe82d3620a51d444aa50d8.JPG
Bottom photo is two low
Middle photo appears close but hose not touching float bowl so can't tell for sure...
Top photo appears very close but hose not pressed up to bowl so cannot say for sure...
But it seems like your getting the idea so be persistent till your happy with it
Ok thanks. I will try and with hose touching flat against the bowl. Thanks man
Bottom photo low with bike running.
Does fuel level drop when running?  Does anyone know if that's normal?
Clogged venting somewhere?
Fuel level doesn't drop. It's just low, when the bike is running
Bike is running a lot better now since I moved the clip on the needle to the second from the bottom or fourth slot from the top. Still won't run with choke on
Great, place the choke in the "OFF" position and ride it a lot.
I'll wait till the air temp, gets cold to try and start it with the choke on. But thanks for your help man
I noticed bike blowing of black smoke on start up and running rough, sputtering. Now it's running too rich. Should I move the clip on the needle higher ? Right now it is 4th from the top or second from the bottom
