gaortiz
Preordered a MY18 Beta 500 RR-S
39 posts in this topic
1 minute ago, hawaiidirtrider said:
That's good. Riding in a group is better. I've been dumb more lately going solo. Last time I fell hard on a simple hill and realized I'm taking a risk. I do tell friends where I'm riding though.
Yup! I have friends track me via different GPS apps when I ride solo. And usually where I ride cell phone service isn't too far away.
1 person likes this
I've got a 2017 Beta 500 rr-s, and it's hard not to ride.
Get a second air filter so you're always ready to rip. Change them out early and often. This way the efi stays in tip top shape, plus your valves will thank you.
Keep a few oil filters and oil on hand because they can be a pain to find in a pinch. I like running the stock motul stuff, and I also like using the paper filters.
New tires are a good idea too. But the stockers work and wear pretty good on the street, and they're not bad for the southern california desert races and off road stuff that I've done with them, At least when they had some meat on em'. There hasn't been one single instance that I thought "Aww mann, if only I had a different set of tires, that would be sweet." Instead just mess with air pressure, clicker settings and shred em down, maybe do a revalve if you feel the need. The stock suspension is very plush and I like it.
The stock skid-plate kicks ass in the rocks. I've got lots of stick marks on mine from sliding over and around these kinds of stuffs.:devil: I like plastic skid-plates better than aluminum because its slicker and slides better. A linkage skidplate is a good idea, just because the bike is so capable it will have you trying stuff you wouldnt attempt on your old bike. My linkage and shock also has quite a few stick marks too. I want to try the obie one, more than the fastway one, but both are cool.
The billet rear brake clevis is a good idea, and it will improve rear brake feel, especially if you like popping wheelies. I gotta tell you though, the stock rear brake clevis is Junque...
I feel that there is a real need to get some steel oil pump gears in the crankcase because then the only worry with the engine is valve checks and oil changes maybe clutch plates too. The clutch is freaking great on my 2017, but I abuse the heck out of it.
At speed the bike is pretty stable and I really haven't felt the need for a steering stabilizer. I'm sure it would help, But I'm not trying to add any unnecessary weight.
heres a quick video to check out my bike in action
https://www.youtube.com/watch?v=3FBf5pvQsYI
The bike really doesnt need much, if anything.
Also dont be afraid to ride the bike, but it does need to be taken apart and greased, and anti-sieze treated.
3 people like this
Thanks for the great suggestions! I just watched part of your 40 minute video. Puts my single track sketchy video the shame LOL.
I'm from SoCal as well. We should definitely meet up and ride when I get mine!
1 person likes this
sounds cool mann, I could use a good ride. Let me know when and where.
I watched some of your videos too. I'd like to ride some of those spots, they look like alot of funn, and thats all that matters.
Posted (edited)
I think the billet brake clevis will be my next upgrade. I agree, the stock one is way sloppy. I'd also suggest removing the brake lever tip and grinding the backside down at an angle. I replaced the hex bolts with button head so if the lever is hit it hopefully will not puncture the clutch cover.
I found my bike had a lot of grease in the bearings. But.... I'd suggest going over the wiring and inspect/zip-tie the more critical molex style connectors. If you ride in the wet a lot silicon electric grease is a good idea. Pay attention to the connectors up at the main panel behind the headlight mask, it's kinda a mess there and quite often they aren't solidly connected, especially the one for the speedo wire.
Keep me posted if you guys decide to hookup for a ride!
Edited by danketchpel
2 people like this
I thought I used my rear tire all the way, but you are about to show some cord there. What's next?
1 person likes this
I have  2016 500 with 140hrs.   I had the usual problems.... Seat too hard, replaced with Seat Concepts with wide front to accommodate the 3.1 gallon Ims tank I have.   Kickstand tip way too small for the terrain here in Michigan. I put on the aluminum pad from Beta and now no more tip overs.  The stock mirrors stalk broke early on, so I replaced them with Doubletake mirrors and I like them much better.  After I used up the stock tires, I switched to the Goldentyre gt216 Hbn rear, love it.  Wears pretty fast if you street ride much, which I do. I go with the Goldentyre fatty GT216aa in the front, it improved handling in sand, a lot.  I balanced the tires for street using the weights in the pic. Bought them online, can't remember where, but they took almost all the shake out. Expensive though.  Front and back 60 bucks, if I remember.  Midwest Engineering short clutch lever works very nice. Reduced clutch pull.  Not sure how much exactly, but it was noticeable and worth the price.   The stock battery failed in the first six months and I have never once been able to kick start the bike. (That's with over 3000 miles on the engine)  Now I carry an Antigravity jumper pack in my saddlebag.  I had the problem with the fuel light staying on.  Covered it with tape, no more problem. The dealer sent out a new part to fix it, free though.  Replaced steel gears at 100 hrs and I always stayed with Motul oil.   (I use the Scotts stainless oil filter,  from Beta, when I built it)
The bike has been great.  Love it.  You will too.
4 people like this
I have a boat and have a bigger, older PLB, then last spring, while looking for additional PLB's, I had come across 4 ACR RescueLink's for like $75 each, I bought all 4, sold one to a brother in law and kept the other 3.  One goes into my fanny pack for when the excrement might make contact with the oscillating blades.
The last two times I have been out riding, I have been alone and stick to the big trails where there is less chance to crash and a walk out from a breakdown would be easier.
2 people like this
1000 miles... It's just barely getting broken in. :D
When it heats up it works great riding the ditches and skateparks here around my hometown.:ride:
I'm not expecting to ride off road till next month so only city enduro for now; streets, alleys, paths, bridges, railways, stairs and such... probably wayyy too many places I'm not even supposed to be at. :devil:
probably gonna do an irc evo and a fatty next month, and start weekend warrioring the dez with my familia when it's cool...
I might even keep her off the streets for a while???
I've been surfing and exercising alot lately, so She's just been chilling, waiting for her time with me...
:cool:
my 2017 beta 500 rr-s has never had any kickstand issues with tipping over and Ive never dropped or crashed her, although I did scratch her up in a small avalanche that we rode out of, and also on some big boulders on a couple of gnarley trails, so I'm cool with the kickstand end. although I am careful with how I prop her up. I dropped my harley because of a junky aftermarket kickstand that folded itself under normal street use, so Ive learned to be careful with my bikes. Sometimes I might use a stick or rock to increase the footprint but it always works out in the end and I've had no worries.
Heres another video just to keep things spiced up.
mellow ride but it was cool
1 person likes this
I also ordered my 500 RR-S this week through BYOB. 8-16 to be exact.  Filled out my suspension form details and sent back today.  According to Beta USA, they should start the build on  9-16 and then 7-10 days to complete customization and ship.  So, I'm at least a two months from getting my bike.  At least it will be cooler in Texas in October. I wound up ordering the following.
Suspension Upgrade, Support Package
IMS Rally Tank, Natural
Seat Assembly by Seat Concepts
4-Stroke Pipe Guard
High Performance Water Pump Kit
Ready for the desert.
Edited by betagetdirt
spelling
2 people like this
4-Stroke Pipe Guard
I was going to order through BYOB but didn't want to wait two months since I have an LA to Vegas Dual Sport ride planned in November. I'll just upgrade as I go. It'll be fun I think.
Sent from my SM-G955U using ThumperTalk mobile app
1 person likes this
Sounds like an intense ride.  How much dirt will you be doing on a ride like this?
1 person likes this
90% dirt, rocks and deep ass sand. Plan on showing all the Huskys that the Beta can be the king of the desert too 🤣
1 person likes this
Around 250 miles?    What a great ride.   I plan on introducing the Beta to all of the KTM's and Huskys around here.
1 person likes this
10 minutes ago, gaortiz said:
No, close to 400 miles. The route zigs and zags a lot!
Woo.  Huge event. Lucky you're in CA and have that open space to ride man.  So is this a race of sorts?  Looks serious.
1 person likes this
Not a race, just a ride. It'll be my first time doing the organized ride but I've ridden that desert a lot. Should be a blast
About halfway through the video now.  It looks tough and challenging but very cool.  That rocky section reminds me of our Chihuahuan desert (Big Bend) where I ride.  Whatever coms these guys are using are cool.
1 person likes this
  • Similar Content
    • By markwoodlief
      anyone running the g2 throttle tamer on their 4t bikes? Just picked one up today. I have installed them in the past on both my KTM and my Hsq 501. But with the beta there seems to be too much side to side play between the throttle and throttle housing, allowing the cable to move in and out of the grooves. I can hear my cable grinding as I rotate the throttle. Any clues? Wondering if g2 was just getting to market quick, since our throttles are basically a KTM 50/65 2t cable, and just put Beta on the sticker.
    • By hill5150
      2008 505 XCF ****Plated*****!!!!!
      $3ooo.oBO.......
      Original owner Bought Brand new 3 BROS Costa Mesa Bike is in pristine condition for an 08.Has an ARIZONA street legal plate.
      all service, valves only, have been performed at 3 Bros.I have been riding bikes since I was a kid -CR 500 XR 650 were the last two I had, this bike is the best bike I have ever owned. Period. Oil has been changed every 500 miles since day one. Getting this bike plated in CA is YOUR responsibility. Or just green sticker it and enjoy the DEZ.
      Last 3 years has been commute only 98% of the time riding 8 or so miles a day. Bike hasn't seen dirt in a while. Motor is strong wheelies all day and is this bike is no longer made. Get it now. You will not find a cleaner, or find one at all 505 XCF anywhere. PLATED!........Lack of dez use forces sale.
      In NEWPORT BEACH
      lavey5150@gmail.com
      here's the goods included-
      -Scott's Dampener-
      -CNC Break away brake lever
      -2 foam desert filters
      -Stock Tank
      -Has a Clockwork 3.5 gal tank on it
      -Has 52 rear sprocket
      2 spare clutches
      -Goggles w spare tear offs
      -K/N street filter
      -2 Foam Dez filters
      -2 sets Brand new pads front/rear
      1 size small MOTO helmet brand new
      -1 Large used street helmet
      -2 front knobbies
      -1 rear knobby
      - 1 Paddle
      -1 gallon 15-50 Synthetic oil BelRay
      2 33 oz 20/50 Maxima Full syn
      -FMF Power bomb slip-on on silencer just repacked
      -Jetted
      -Dirt Tricks Cam tensioner
      -R/D float bowl-Awesome response!
      -Upgraded silicone hoses
      -GPS E-trex w/ Mount
      -Fox fanny pack
      -50 tooth rear on bike aluminum-orange
      -Stock 50 rear spare and chain
      -X-2 Trailtech Light
      -SICASS rear tail light w/brake light LED
      -SHORAI Lythium battery saves 80% weight
      -Bar mount mirrors
    • By Morgan Williams
      81 hours on engine and 2,281 miles on the odometer. Runs great, well maintained, mostly by Malcolm Smith Motorsports. Have clean title ready for sale in Riverside 92504. Please note bill of sale will read actual sale amount. Available to see all weekend and weeknights after 6:30pm only. $8500
      Highlights
          •    Heavy duty WP rear spring and forks revalved
          •    Handlebar risers
          •    Many orange anodized parts
          •    Shorty LED turn signals, front and rear
          •    Short license plate holder and LED brake light
          •    Shorai lithium battery
          •    Orange anodized Talon rear sprocket
          •    Red Bull KTM graphics
          •    Right rear KTM Powerparts handle
          •    Carbon fiber head pipe guard
          •    Blue anodized Bullet Proof radiator guards
          •    Quick-mount HD plastic skid plate
          •    Seat Concepts seat with custom Motoseat cover
          •    Metzeler Six Days Extreme tires
      Extras:
          •    All original plastics as shown
          •    Original rear fender, brake light and all turn signals
          •    Original battery
          •    Extra Red Bull KTM decals
          •    Original rear spring
          •    Original brake and clutch fluid covers
          •    New oil filter and screen kit
          •    Original handlebar clamps
          •    Acerbis full handguards
    • By sasrocks
      The Beta 250RR is a premium Italian enduro bike with a slightly lower seat height than KTM and excellent handling and power. The 250 has awesome low end torque and still revs higher than a 300, allowing for more usable range of power and actually less need to short shift the bike. Plus it has less rotating mass in the engine so the handling feels more nimble. Design features and mods of this very clean well maintained bike:
      Electronic Variable Oil Injection design, no mixing of fuel required! The oil tank holds enough for up to 3 tanks of gas.
      Dual Ignition Map soft and hard power curves
      Adjustable Power Valve; can completely change the power characteristics from linear to a distinct hit (which is easy to predict and ride thru). I have the soft map + distinct hit tuned via the power valve ( a simple hex head bolt adjustable without removing any cover). This combo makes for plenty of grunt in the woods, but not so much that the throttle is jerky. then when the trail opens up you have the awesome power up top when the power value opens up.
      Suspension revalved and resprung by Stillwell (The Beta experts) for 190 lb rider.
      Rekluse 3.0 Core EXP Clutch: top line of the auto clutch, is a magical addition that makes any ride better. can still use clutch manually to pop over obstacles etc.
      Full off road protection:
      Aluminum Pipe guard
      Acerbis Hand guards
      Rear disk guard
      EE skid plate
      BRP radiator guards
      Clutch Slave guard with brush bar
      Ox Brake Left Hand Rear Brake; simple cable system to operate brake with foot or hand
      Beta Fork Bleeders
      Larger kickstand foot to not sink in the mud
      Goldentyre Fatty front tire; unmatched traction
      Shinko 520 rear tire; recommended with Tubliss system
      Tubliss system Front and Rear: dramatically improves traction; can run much lower pressure safely and maintain much better flat protection, also with lighter weight than HD tubes. You can run safely on a flat tire back to the truck due to this design
      PLUS: Registered and Plated in Missouri. Along with the oil injection you can dual sport this bike and fill up along the way without having to mix oil. It will maintain 65 mph with stock gearing and still crawl in the technical sections. (lights removed currently. Horn retained so you can honk to alert slower riders in the woods )
      All Extras
      Stock skid plate, DOT Michelin tires
      (oil tank currently removed)
      Bike is maintained regularly. Steering, swingarm and linkage bearing greased with Bel-Ray waterproof grease. Fresh Rotella in gearbox. No Toil air filter oil used. Extra Twin air filter included
      Parts are reasonable and very easy to get. 285 miles, 18hrs
      This bike is ready to roll: race, trail or dual sport. It is set up perfectly and better than new with Rekluse, suspension, Tubliss LHRB and all the protection parts.
    • By F-inEdd
      This is my first thread here, been searching online for some help with no luck. I have a 2001 wr250f i picked up for 1600. Someone already did the conversion to dual sport. Well, my control switch went bad and i got a k&s universal one. Now nothings working. Been trying everything. I was hoping someone has put one of these switches on before and could help me out a bit. I have gotten the headlight to come one. But only the hi beam.
