Notch in rear brake arm
I searched eBay for a photo of a notched drum brake arm.  This mod allows easier installation of rear wheel.
I'd like to see a photo, then, of course, reinvent the wheel.
I don't have any XR250R drum brakes for a picture but here is a part fiche from another thread that shows the parts. #10 is the important part that allows the brake rod to be disconnected from the arm.  Also need other parts to keep the rod connected during use.  https://thumpertalk.com/forums/topic/1237402-how-much-weight-is-lost-with-a-rear-disc-brake-conversion/?do=findComment&comment=13856797
I don't think that's what I'm envisioning.
I want to be able to disconnect the rod from #10 before I remove the wheel.  Then install the wheel, adjust the chain, then connect the pull rod.
