Bike vibrates more after jetting change??
try adjusting your air screw and idle with jetting changes to smooth it out. If no help there, go back in and make sure you got the carb back together right.
i am thinking that the problem is not that, i also took the front end apart to re grease the steering bearings at the same time as i did the jetting and i believe that i may have not assembled it right or may have lost a part or remounted the handle bars wrong
I troubleshoot complex equipment for a living. As usual, "the rest of the story" comes after the initial report, and the cause is obvious. :facepalm::lol:
  • Like 3
