water pump gear, plastic vs steel, what years?
So while working on my 1996 cr250 rebuild, noticed the water pump gear on my 1996 is plastic.  On one of the spare engine cases, the water pump has a steel gear.  What years had the steel vs plastic gear?  I am thinking the steel would be preferred.
If steel is better, is there any reason to split the water pump cover?  The other was a pain in the butt and not sure it was necessary.  The right side cover the steel geared water pump is on is in good shape, should I just use it instead of swapping the steel pump from one to the other?
