2008 kxf450 fitting lights
Hi all
first post here :)
just purchased a kxf450 2008
its got a daytime mot . I want to put a tail/brake light , indicators and a headlight . Speedo dash etc on it so I can get full mot . I've heard a few people say that this bike stator is capable off running this .
Is that possible or is there a stator kit out there for this bike I need to buy
appreciate any advise regarding this
scott
Hi all  first post here
scott
I'm pretty sure it is the same stator that my 06 has in it. If it is then it does not supply enough power. You would need a new one that supplies enough. Here is a forum I was looking up when I was thinking thinking of doing mine. Had some good info on it. http://supermotojunkie.com/showthread.php?112877-Turning-my-KX450f-into-a-street-legal-hooligan-machine!-What-parts-do-I-need
Sent from my XT1585 using ThumperTalk mobile app
Had a better look today and it's already got a rear brake light switch and an extra loom off the stator so I think it's been wired for lights before ,
going to test the feed and go from there onwards
thanks for the link I'll have a good read !
Edited by spudboy6
Got down and dirty with it today
the stator loom goes up to the usual grey factory plug behind the rad but also has two yellow connectors coming out off it that are not connected to anything , far as I'm aware these are the charging wires
ive tested it and both these yellow wires produce voltage (A/C)
ive installed a regulator rectifier to connect it to DC,
how would I connect this to the stator.  Would I use one yellow wire for + and use the frame to earth at the reg/rec
or is one yellow wire the + feed and use the other as the - feed ?
Ive checked the wiring diagram for my bike and they don't show these two yellow wires so led to believe this is some sort offf lighting kit but if you have an 08 450 let me know has yours got them ?
Any idea on how to use the yellow wires ?
Got to the bottom off this
the stator /lighting coil fitted is single phase so if you place a bulb against both yellows you get A/C
i purchased a single phase regulator rectifier and all is well I'm not getting charge for my battery to power my lights
Fitted a much larger battery and a led light bar now ,
All working fine and charging perfectly fine as the bigger battery covers the load and is topped up by standard stator
IMG_7358.JPGIMG_7170.JPGmmy battery mock up
  • Like 2
I’m now considering selling this , I really like the bike but would like to possibly get back on a sports bike or an bmw m3
if anybody is looking for a mint supermoto that’s been road registered since new .
As above full light kit
Mot
Talon wheels with Michelin
Tracker fitted
Fmf power bomb
Vapor dash
Side stand
Comes with 8 oil filters
Well serviced and ready to ride
Message for any info
