Looking for a reliable LED flasher relay
This seems to be the most common one on the market: https://www.amazon.com/dp/B003UN4FXW?tag=viglink20633-20
But so many people wrote the same comment: It worked for a while, then suddenly quit because one of the components inside snapped off as it had been bent to fit.
Anyone have a product link to a tried and true LED flasher relay ??
I have pretty much the same one. Got it off ebay for a few dollars less. Plug and play, and worked fine for like a month, until my piston siezed. Bike is still down though, so only have about a months experience with it
Thanks for all the replies. Seems it's hit or miss. Another question: did anyone need to install a diode for everything to work properly with the dash indicator bulb? I had to install one of these for them to work on my XR: https://www.rockymountainatvmc.com/p/1196/31771/Kuryakyn-L.E.D.-Turn-Signal-Diode-Kit
Edited by md30
1 minute ago, md30 said:
Thanks for all the replies. Seems it's hit or miss. Another question: did anyone need to install a diode for everything to work properly with the dash indicator bulb? I had to install one of these to them to work on my XR: https://www.rockymountainatvmc.com/p/1196/31771/Kuryakyn-L.E.D.-Turn-Signal-Diode-Kit
Everything should work fine on the DRZ with just the relay installed. I plugged mine right up and all the lights functioned as they should.
I didn't need to install a diode. everythign worked fine as is. plug and play
