01 wr 250f gears in 00 yz 250
Curious if im able to put my 3rd 4th and 5th 01 wr250f gears in my 00 yz as the yz refuses to shift into 3rd and only gives a false nuetral, am also converting into a woods bike but i dont mind the slightly taller 1st and 2nd. Thanks.
No you can't. The shafts are a smaller diameter, only 400/426 and 450 to 05 will swap.
By the 3-5 kit on RMATV/MC for 380.00 I believe is what it costs. But you might need forks also. Best to split case, inventory parts, order, and go from there.
Good luck, let us know what you do.
Thanks guys, had a feeling it wouldnt work but thought id ask anyhow. Will try to keep yous posted on how my mx to offroad yz rebuild goes :)
2 hours ago, tchetek said:
How much case modification is required to fit 1st gear in there?
Very minimum, look through my restoration thread and you'll see photos.
Thank you.
I will search!
