Yz400F unfixable carb?
I recently bought an YZ400F, and opened rhe carb and it looked like this: https://m.imgur.com/a/mVg2F
The bike started, but with very high idle. Can this be the cause? And is it worth fixing or should i just start looking for a new carb?
All answers are appreciated :)
I would clean your carb really really good and replace all jets and seals that need replaced. Make sure to clean the pilot screw circuit really really good as it has a bend in it and tends to clog up often.
Sent from my SAMSUNG-SM-G890A using ThumperTalk mobile app
I dont know if you can see it very well in the picture, but for me it looks like the throttle slide plate is broken. I have checked the engine, and there is no debri in there. And it also looks like it can get air through it easily with that big piece broken off
Sent from my SM-G930F using ThumperTalk mobile app
Woops, linl was broken, hope this works
Link didnt work cuz you had a period at the end. Ya at the top off to the right a little bit. If it is broken or cracked replace it. If you want to replace the carb with the same carb it's gonna cost $$.
How hard is it to change just the slider then? And will it be as good afterwards? I am looking for a new carb, but as i am quite new to this, i dont know how much work everything is. I did look at this: http://www.keihin-fcr.com/index.php?route=product/product&path=111_107&product_id=57 , but dont know if its worth the 475$ + shipping to Norway(usually about 100$+)
Fixed post.
New vacuum release plate and seal. Common weak spot in that model year carb. Might also want to get a new pilot jet and ensure the fuel screw is 100% serviceable. I'd do this and not risk buying another guys headache.
The site you linked to is suspect. Some have gotten good stuff from that guy, some garbage. Do not let the name mislead you into thinking it is an authorized dealer, it is a guy in a garage.
Change the slide and seal. Clean the shit out of the carb and go from there. It is very easy to do. Shows you In the manual.
Yup I agree, no need to replace that carb. Buy a manual and the right parts and it will show you step by step on how to take it apart, clean it, and reassembly. Easy peezy lemon squeezy. You will save hundreds of dollars. Go on bikebandit.com for a carb diagram and either order from there or get part numbers.  Clean the crap put of the carb, carb cleaner, compressed air, pipe cleaners, whatever you gotta do, buy a rebuild kit and a new slide and whatever else needs to be ordered. Shouldn't take more than a half day to get her back up in running shape.
5 hours ago, Valo said:
Since im kinda new to this, i want to make sure i order the right items. It also takes along time to get it since i live in Norway.
http://www.ebay.com/itm/272685467449
http://www.ebay.com/itm/272686665403
That carb rebuild kit is not complete
You need to order by the piece
- slide plate
- slide plate seal
- fuel screw oring
- bowl gasket and orings
- float needle
- new pilot jet
- new hot start cap (get an aluminum one, not the oem plastic)
- accelerator pump upgrade kit      http://www.crfsonly....roducts_id/3932
JD Jetting, Jetsrus.com, or Sudco can help you with all but the nut.
For cleaning the carb body I’ve had good luck with berryman’s carb cleaner that comes in a 1 gallon bucket. It has a basket. Just don’t leave stuff in there too long. I don’t know what’s in that stuff but pretty sure it’ll eat about anything if you leave it in there too long. It cleaned my carb that had sat in rotten fuel for years without any issues at all. It’s some strong stuff.
Edited by Schpenxel
^ DO NOT DO THIS ^
There is a neoprene split body seal on the FCR carb that will be damaged by diping in real solvent.
Even if you only dip in for 10 min, the melting of the seal will continue until it's completely deformed.
The only reason to soak an FCR carb is if there is visible green corrosion, or if the check ball in the apump system has corroded/stuck.
Use Simple Green or Pine-sol if you have to soak, and leave it in for a day or two.
The only passage other than the apump system that has a problem is the passage above the pilot jet, which can be reamed with small copper wire.
Apologies for the bad advice--It worked for me but sounds like it isn't a great idea and I may have issues down the road because of it.
