2017 500 EXC - Intermittent Running
Check out the ADV rider who found loose crimping under the ground wire heat shrink:
http://advrider.com/index.php?threads/2017-500-exc-f-and-350-exc-f.1146410/page-167
Think I'll pull mine, remove the insulation and use a punch to check crimp tension. We had this happen on the June ride to a 2014 450 XC (+ wire)
Edited by Burnrider
I'll tell Bob, same thing on his '14 XCW on the Nevada ride. Bike would idle and cut out on acceleration. When Kips same bike did it this year, I had them pop the seat.
The '14's might have a specific issue with breaking. This post is for the '17 riders with intermittent running issues checking the crimp grip on the battery strap. You should be able to pull on the wire with pliers to check for a secure connection.
Edited by Burnrider
on my 2017 , the ground bolt was mot going all the way in , it was to long  hitting the end off the tread making the ground cable not tight enough . the bolt that attached the ground cable to the chassis . i just install a washer .
