1993 rm250 head difference
I snagged up an 93 rm250 for cheap.
It needs a new head among other things. I'm wondering if a 96-00 head will work or not? Any one tried this?
i'm guessing if the holes line up it should work - top engine mount location is different and also coolant hose location is different
My main question is with the coolant channels and flow direction. Will a different head cause issues cooling? Also I had read that some years had a piston that went slightly into the head.
I'm not opposed to modifications to get a different more common head to work.  Also it appears my head/frame mounts is slightly off center.
Here is what my head looks like. It's damaged badly. FYI.
You might be able to get that head cleaned up and re-use it - i would head down that direction first
