88 Cr250 PowerBand not kicking in?
Got my 88 Cr250 was idling odd so I cleaned the carb and tried adjusting the idle but can't get it perfect and now ithe will wind up like it's about to snap into powerband but it acts like it almost hits a rev limiter and gets some power but definitly does not sound right, any help much appreciated.
Since you just had the carb apart I would look there first.  Just because you cleaned it doesn't mean its clean or working correctly. Make sure you're tank is free of contamination and your fuel line is not breaking down and is still good. Then check you fuel flow to make sure nothing is blocked. Re clean the carb, maybe replace both jets with new ones just to be sure. If the bike still doesn't run right go from there.
Also naked sure you're airfilter is clean and there's nothing obstructing the exhaust.
