88' to 91' Honda CR250 HPP Cleaning and Setup info
Hi All.
I keep seeing people having troubles with their HPP valves on the 88' to 91' Honda Cr250s. I have been working on restoring a 1988 CR250 and when I put my engine together I had a bit of a hard time getting the valves setup correctly myself. I had an 88' back when they were new and did work on it back then but forgot much of the setup. Once I relearned it I am pretty good at the setup now which is good as I have another engine to assemble soon. I thought I would share some of my references and answer any questions if anyone has any trouble with this. I have shared some good PDF versions of some of the sections from the manuals. If you are a facebook user try joining CRs Only. https://www.facebook.com/groups/771937119520313/files/ There is a files section there where you can download the FSM and owners manuals for these bikes. There are also a copy of my files focused just on the HPP valves posted there. Here is some of the info converted to Jpeg to post here. A couple of those pictures are the 86'/87' valve setup which is very similar. There are only a couple differences. The pictures help to get an idea of how it all fits in the engine. I hope this helps out a few folks. Feel free to ask any questions and I will do my best to answer.
Greg
:thumbsup::thumbsup: And one ounce of SeaFoam to EVERY 2.5 gal of premix with a high quality oil appropriate for your use will forever eliminate a need to clean them again.
Edited by YHGEORGE
This is great, thank you! I'm building a '86 cr250, I will definitely be frequenting this thread now on how to do the powervalve.
Yes. That might reduce the cleaning but there will always be a need to know how to disassemble and reassembly this stuff for other engine maintenance. Not to mention how to get them adjusted correctly.
Greg
The 86' 87' is just a little bit different but it is quite close. You still adjust bolt #4 for the correct spring closing preload. Just a couple of different pieces but same overall application.
Greg
You can run the bike with the powervalve cover off? I thought that would be like an air leak and cause lean conditions.
Being it is not on the intake or crankcase it is not an air leak. This is only a slight exhaust leak when running. No problem at all.
Greg
Greg
That had already been addressed quite thoroughly.
