Please help with changing left engine cover.
2008 Honda CRF150R engine cover damaged on a rock this last weekend, ordered a new OEM replacement.  Now I'm moving the parts from original cover to the new and I came across this part named VALVE ASSY, RELIEF held in by a circlip.(ITEM 4 in the images below)  When I removed it, I did not pay attention to it's orientation.  Does anyone know if it needs to be installed a certain way?  Thanks in Advance!!!!
2 hours ago, S.O.A.N.Z said:
O-ring #15 side in case first
Thank you. I should have been more clear, I meant orientation on the other axis.  Is there a point that should face a particular position on 360 degrees?   I'm thinking it doesn't matter.
