2008 yz450f Kickstart lever fitting??
Whats up everyone I'm pretty new to the forum so I'm not sure if I'm posting in the correct spot.Either way I need some help! what year kickstart levers will fit my 2007 yz450f. I got away with a Kim lever off a 525 exc but now I'm looking online and can't find much but one option for 130$ I'm seeing a lot of options for 2011 levers around 75$ and they look nicer with a blue instead of silver. Does anyone know what size the spline is? what other years I could possibly use? thanks in advance. On another note my oil filter housing bolt is stripped like most I see are dealing with. I have googled away and cannot seem to find where to order that bolt.
Try Rocky mountain ATV mc or bike bandit. Go to the OEM parts tab and enter your bike. On bike bandit there should be an option along the lines of see compatible parts. So that will show you all the other bike with the exact same kick lever. If you use the OEM parts finder you will be able to find that bolt too. If you still can't go to the hardware store and they should have a similar one just it won't be as nice looking of a bolt
All these are the same
Assemblies where 2S2-15620-00-00 is used
2006 YZ450F (YZ450FV) - Starter
2006 YZ450F 50TH ANNIVERSARY (YZ450FSPV) - Starter
2007 WR450F (WR450FW) - Starter
2007 YZ450F (YZ450FW) - Starter
2008 WR450F (WR450FX) - Starter
2008 YZ450F (YZ450FXL) - Starter
2008 YZ450F (YZ450FXW) - Starter
2009 WR450F (WR450FY) - Starter
2009 YZ450F (YZ450FYL) - Starter
2009 YZ450F (YZ450FYW) - Starter
2011 WR450F (WR450FA) - Starter
One here      http://www.ebay.ca/itm/2006-06-Yamaha-Yz450f-Yz-450f-OEM-KIcker-Kick-Starter-Lever-Pedal-Pivot-Joint-07-/232450194583?hash=item361f1c7c97:g:kl0AAOSw539ZbWGi&vxp=mtr
Thanks man!!!! Exactly the info I was looking for 💯
