Guess this problem
Just for kicks, I was wondering if anyone can guess what was wrong with my kx250f
Year:2011-fuel injected
After a total strip down restoration of a semi beat down 250f, when it came time to start it for the first time, it would start first or second kick, then die and not start for a few minutes, then repeat the symptoms. What is it? As soon as someone guesses, I will verify.
Hint-Bike ran fine before I did the work
Work performed:
Bike stripped down-every nut, bolt and clip
Cases split-new bottom end-
Both cases replaced
New cylinder, piston, rings
Valve seats and new titanium valves
Clutch
Pretty much everything else on the bike
electrical.  Maybe vehicle down sensor
When reassembling the bike. I accidentally put the down sensor back in upside down. Took a couple hours to figure out, but only a minute to fix.
  • Like 3
