Phillips head screws in powervalve won't come out. 2000 YZ250
I have a new cylinder and piston for my 2000 YZ250 and need to take the powervalve out of the old cylinder.  However I can't get the Phillips heads screws to budge.  I haven't stripped them yet but it's inevitable if something else doesn't work.  Do any of you have any suggestions?  Do any of those anti seize liquids work, impact drill, I am certainly open do suggestions.  I do not want to have to pay for a new powervalve when I have a perfectly good one that's just being held in by 5 stubborn screws.
Thanks
Mine were the same, impact driver is the route. Basically a big steel screwdriver that you hit with a hammer and it turns it self might even need to use heat. They must use red loctite when installing
  • Like 2
If you have a cordless impact drill, it will work better than the manual kind. You can also get JIS bits.
Edited by 351mustanger
