Jetster220
crf100 tk racing suspension link
trying to figure out the part # on the rubber bearing seals for the TK link anyone know??post pictures below>
Edited by Tx121
heres the pictures.. not sure why it double posted likes this but whatever .
Can someone who has the TK linkage please measure the center spacer that I have circled I am trying to find a replacement,  I tried using the one off the oem crf100 setup and it's to short to fit inside the custom top spacers that it came with ,that and I am trying to figure out which o rings I need to buy .. anyhelp would be awesome ... I am so close .. running out of options may have to just send the whole thing to all balls.. to fix
Edited by Tx121
Trying to figure out the middle sleeve length .. I need someone to measure that for me .. Anyone ....
Yes it is if the person who was this complete would measure that one upper sleeve I need i can replicate this..
**i finally got the bushing made custom from a machine shop!** had to buy a digital caliper MM to measure then i 3d printed the actual needed test piece..LONG PROCESS.. :--(.. BUt  not only bushing the seals add billet spacers and being i am going through this build right now TK had 2 designs i found out..  1st one which was early model xr100 swingarms which had bushing issues or bearing one or the other where the link would bend . and or the crf verison they made THEY ARE NOT THE SAME one is 1 7/8" other is 2 3/8" and by that i mean the mount on the swing arm for the TK link i had a 2000 xr100 swingarm which of course i had a crf TK link so i just ordered a 2005 swing arm which is the new larger size linkage.& i will say i just got my kx100 fork stem back from my local suspension shop had the TK billet xr/crf stem pressed in still have a long way to go on the build will post updates here shortly got a powdercoating system i am about to build out at our office for small personal projects should be just big enough for the frame and other odds and ends!. now with that being said i do have a MINT 17" DID alum crf100 wheel with tire holds air, no dings, not bent from a cr80 with a drum hub . DIRECT bolt ON for the xr/crf100 !. thought i would ask you guys before i list it any where else.. ! makes a night and day difference in terms of handling ! i now have a full KX 100 front setup so no need. 125$ shipped takes it PM me for pictures .paypal recommended * note-i paid 135$ for the wheel alone with out the HUB shipped on ebay last yr hard to find some what rare
Edited by Tx121
Kicking this thread back up.  I need measurements from a TK link and I will replicate them.  If anyone has one to be measured let me know.  I do not want to buy yours, just take some measurements.  Thanks!
  • Like 2
Any update or projected production date on these?  IMO I would make the bushings/bearings OEM size, that way it is easier to source replacement parts, stock or aftermarket.  Having custom bearing & bushings was a disadvantage of the TK link...gotta make it feasible to replace worn parts.  Thanks.
I was just thinking about using Allballz.  I think that's what he used.  That way, you can get everything as a kit.
All,
I am working on this stuff now.
Please express interest on the above thread.
Edited by Mrrcx
I did end up making links, I also made some conversion steering stems to run CR80 forks.  The link I make at the moment works on the 01-03 XR100.  I plan to put efforts into the 85-00 and 04+ generations over summer time.  PM me for more information.
Time to get started on the 85-00 generation rear link.
This one almost looks too pretty to take apart!
  • Like 2
