need help identifying part on yz250
so i have a 2016 yz250 2 stroke i was changing the main jet and the jet got stripped and bent the little needdle inside were u put the main jet in at what is that needle called and what part number is it please help
...also, when removing, confirm the letters on the side, they identify details about the needle. In the above post, the needle is a N89G, you may have that one or a different one. Get the same as you currently have. Do not try and straighten your bent needle, you bike will not run properly even if you think it is 'fixed'. Finally, note the clip position, make sure you put it a the same spot on the new needle.
ttr paul ,
take this opportunity to change it to a better needle then what yamaha offer
