Polisport Re-Style kit on 07' 125
Having issues ordering graphics, it appears front fender, shrouds, front and side number plates are OEM 2015-18, the only odd part is rear fender looks like 10-13 YZ250f, is this correct ?, they sent graphics for a UFO re-style and it not even close.
Where did you get your graphics from?
All the restyle kits have different templates.
I might be dense, but the question is confusing to me.
Did you already order the graphics, or are still shopping?
Do you have the Polisport kit?
"Restyle" can mean different things depending on the vendor.  Originally "restyle" meant the UFO kit, which is unique and non-OEM regardless of year, and since 2015+ that term is sometimes thrown around for the newer OEM plastic style.  And that can confuse things when ordering decals.
  • Like 2
DESCRIPTION YZ Restyling kit
Polisport releases the new YZ restyling kit. With this MX plastics kit, which also includes the airbox, you'll be able to completely update the looks of your YZ, from 2002 onward, to look like the new models. This kit is also perfect if you want to replace the airbox on a 2015-2017 YZ models. All you need in just one kit.
The only part that isn't an aftermarket OEM copy is the air box, the shrouds appear stock replacements 2015-2018, so it looks like you just order graphics for stock 15-18 plastic. They use the current 4t front fender and it needs a couple new holes punch and the front number plate requires a little  trimming around the bottom.
Edited by ktm300
If you want to design your own, MotoCal has the template and you can make them however you please.
Everyone has the template, Polisports Restyling kit just up dates everything to stock 15-18" plastic, it's not really restyling it's updating.
