Difficulty starting, won't idle, power loss
2008 crf250r. Just installed new gaskets for top end and new rings. I also adjusted the valves since the exhaust side had tightened up. I cleaned the jets in the carb prior to the top end work (which took about 3 weeks) It is still as difficult to start as before and i have to give the throttle a slight twist when i crank for it to start up. It will not idle and feels like it's significantly slower. I didn't ride it much before the top end work so maybe I'm just used to my 450 but it seems like it's sluggish. It doesn't pop at all though so what could be causing this?
