Thanks.  I was going to order a set of the warp 9's because they come with rotor and sprocket.  I want to make swapping as easy as possible but dont want to ruin anything out of laziness.
If the rotors are made of the same material, I'd not bother to swap pads. If the rotors are of a different metal, then yeah, I'd keep pads with each set of unique wheels.
Also, buy a lot of master links. Ity is reccomended not to reuse the clip though if you are carful and know what to lok for regarding wear, you can, esp. if you safety wire the clip closed.
  • Like 4
I had 2 different setups with different front rotor sizes and brackets and drastic different rear sprockets sizes and different chains.
Made swapping pretty easy.
