2015 wr450f suspension questions
Hey guys and gals, finally looking into getting my suspension set up for my weight, I've found the spring calculator and all that jazz, my question is when do I need to revalue it's stock at .46 in the forks and I'll be moving to a .50-.52 will this require a revalve? Would there be anything to revalve on the rear? I'm going to up the print rate back their also, thanks for the help!
It's close to needing a revalve , might get away with it
winning by 4:1 lol
Worth the money while I'm in there? Or spring it and give it a go first? Any ideas what I'd need to look for to tell if it did need a revalve?
It's normally the rebound , I'm not sure if the STD wr has lots of rebound ie enough to cope with those springs , what do you weigh ?as they are stiff
winning by 4:1 lol
0.50 is as stiff as I would go
winning by 4:1 lol
Fair enough, would you spend the 300 bucks on valves for just moving .4? thanks for the help man!
I think I would , it's a good jump in rates
winning by 4:1 lol
