2013 rmz450 fuel issue
I have a 13' 450, the fuel pump it not getting power, I have check the pump with battery and it works when not plugged into the bike. the bike has spark, and I checked it with the same plug that's in the bike. any info or help would be great. thanks.
Try hooking a battery to the service coupler to see if the fuel pump turns on first and foremost. If it does not, backprobe to the connector 10 on the ecm harness (red with black wire) and ground that wire to the frame, with the battery Connected. The fuel pump should turn on. If so, your ecm is bad. The ecm contains the fuel pump relay.
^^^ That and check to make sure the fuel pump connector is clean and making good contact.
