2002 RM 250 rear brake help?
Wondering if anyone has any tips on how to improve the rear brake performance on an '02 RM250? Is there hardware from a later or different model that bolts up?
On my 03 I have galfer braided steel lines, EBC supercross disc, and oem pads. I've tried ebc pads but the oem ones are hard to beat imo. The steel line made the greatest singular difference for me.
The pedal is the only difference between the 02 and 03 rear brake I believe.
I have to same year RM and the brakes are great. Can you be a little more specific of what your brakes are or are not doing?
2 things I would do if I were you is change your brake fluid to Dot5, and while doing that, bleed your brakes in hopes that you may have some air in your brake line.
You could also adjust the brake lever a little higher.
  • Like 2
