08 450 exc Top end/ Cam chain
I am replacing the piston and rings in 08 450 exc and while its apart will be changing the cam chain. New chain is a genuine KTM so the is no joining link. The tooling that i have is to big to press the pin in and out. Can I change the chain by removing the side case and clutch without splitting the chain. Have not worked on the XC4 engines.
Thanks Dave
DO NOT SPLIT THESE CHAINS!!!
Once you remove the flywheel and possibly some chain guides, you can fish the chain over the crank and out.
Thanks Dave
I have the same bike and am planning the same work this winter, curious if you are going to update the the cam/kick decompression system as well and wondering which piston kit you will be using, ktm or aftermarket.
I have 260-270 hrs on my original parts still.
I wont be changing the cams etc as they are still in good condition. Genuine cam chain and Piston and rings. I bought a piston before stripping down the engine and found the barrel has some light scoring so Im getting it re plated as I can not return the piston/rings as they were ordered in. The piston rings are still within spec at 187 so pretty good wear. Will end up costing around the same. Putting in a ProX rod. The cam chain can be removed by removing the flywheel and the cam  slides.
