Tokyo Manual Cam Tensioner Question
Hey all,
Installed my Tokyo Manual Cam Tensioner last night and want to make sure I have the tension right.
I moved the engine to TDC with the cams not touching the valves. I installed per the instructions with a 2mm preload
before securing the two bolts down. The engine sounds good with no noise but I am concerned that too much tension may be applied
because other versions of tensioners say to tighten up the tension screw then back it off leaving little to no pressure on the chain.
Thank you in advance for any feedback.
