Front spring swap
2014 400s
Bought some racetech front springs using there calculator for my weight. Is it a direct swap with the factory springs or are they different lengths. Included in the package was 6 shims, about 1/2 inch total per side I'm assuming for sag adjustments. What can you tell me, thanks....
usually you want about 10mm spring preload, give or take 5.  Start there see how it is, kind of difficult check sag on forks
I would start with 20mm of preload and then check the sag settings. It's preferred to shorten the pvc spacer to the correct sag then adding a stack of washers.
