CRF150R POPPING ON DECEL
I have a 2007 Honda crf150rb that pops whenever you let off the gas. Valves were just shimmed and they're all in spec. Jets are 135 main 48 pilot and rest are stock. Fuel screw is at the factory 2 turns out. It has an fmf powerbomb header and q4 muffler with spark arrestor taken out. I'm thinking that might be it but I want to get the opinions of some other people.
Thanks
Luke
I'm quoting CRF DOC here: "Decel pop is most commonly caused by a lean condition in the pilot circuit or an incorrectly adjusted fuel screw, a missing o-ring or washer on the fuel screw, a partially clogged pilot jet, a clogged passageway above the pilot jet, or a poor sealing crush gasket at the header can all be causes of decel pop."
From this thread:
Edit: note that the crush washer at the exhaust port is designed for one-time use.
Edited by Old Plonker
From this thread:
If I leave it alone will it cause engine damage?
If it is the crush washer it might cause erosion of the gasket face making a good seal impossible later with a new gasket. If it's any of the other things, it will just be a pain in the ass to keep it running clean.
If it were me, I'd chase down he problem and fix it. If you do get into the carb, do yourself a favor and install a flex screw in the pilot circuit. It makes pilot tuning SO much easier.
Alright thanks for your help I’ll try it
