drz 125 crank case won't come off
im trying to replace my clutch plates  and my crank case cover will not come off its stuck above the oil filter the whole case is open expect above the oil filter. I've tried hammering around the case I hammered the metal studs around the case to slowly open it but the one stud broke don't want to break the case I need help I want to ride!!!
7 hours ago, ryan_cin said:
I've got a drz in my garage so I can check tomorrow morning but try taking out the oil filter and checking for bolts and are you sure you got them all out?
Ok thank you but I can try but I've watched videos with the same set up and they just come right off and I looked for bolts see nothing
Maybe try gasket remover or use a butter knife to try to break the seal. If it's just in that one area then there's probably something in the engine getting stuck
